using-the-wiki:getting-started
Both sides previous revision Previous revision
using-the-wiki:getting-started [2017/04/17 14:43]
joberk
using-the-wiki:getting-started [2017/04/17 14:44] (current)
joberk
Line 6: Line 6:
   * [[using-the-wiki:​getting-started:​creating-a-page:​|Creating a page]]   * [[using-the-wiki:​getting-started:​creating-a-page:​|Creating a page]]
-====== Creating a page  ======
-There are several ways to create a new page.
-Find more information about the different ways here: [[https://​www.dokuwiki.org/​page#​create_a_page|https://​www.dokuwiki.org/​page#​create_a_page]]
-Let us imagine you solved a problem about the FarmBot and you want to create a new page about the solution in the topic [[problems-solved:​|problems-solved]].
-First go to the topic, in which you want to create a new page.
-{{ :​using-the-wiki:​screenshot_18_.png |}}
-Now edit that page clicking on the pencil symbol on the right.
-{{ :​using-the-wiki:​screenshot_24_.png |}}
-{{ :​using-the-wiki:​screenshot_19_.png |}}
-To create a new page you can simply create a link for the new page. It will be created automatically.
-Use %%[[HIRARCHYOFTHEPAGE//​NAMEOFTHEPAGE//​]].
-The left part shows where you are creating the page.
-When you want to create your page as a sub page of [[problems-solved]] write[[//​problems-solved:​nameofyourpage//​|nameofyourpage]] %%.
-So in our case we typed in %% [[problems-solved:​mynewsolution|mynewsolution]] %%
-Always use "​-"​ instead of spaces and divide sub pages with ":"​. ​
-Than type "​|"​. The right part shows how the link should be displayed.
-{{ :​using-the-wiki:​correct_20.png |}}
-And that is what we have created:
-{{ :​using-the-wiki:​screenshot_21_.png |}}
-Now you can click on the created link to get to the new page.
-On the right there is the button "​Create this page" (+ pencil).
-After clickong the buttom you can edit the new page.
-On the left corner under the FarmBot logo it says "You are here:" There you can see if the hierarchy structure is worked out.
-{{ :​using-the-wiki:​createpageexample_two.png |}}
-Now you can edit the page using the editor. ​
using-the-wiki/getting-started.txt · Last modified: 2017/04/17 14:44 by joberk
