farmbots:northeastern-wisconsin-technical-college-farmbot
Both sides previous revision Previous revision
farmbots:northeastern-wisconsin-technical-college-farmbot [2016/12/15 16:15]
mgrimmett
farmbots:northeastern-wisconsin-technical-college-farmbot [2016/12/15 17:10] (current)
mgrimmett
Line 1: Line 1:
-**Current Status** - Farmbot construction is 90% complete. Tool holders need to be mounted, ​final wiring for power source and pi need to be routed and completed. ​Vacuum and water inputs need to be hooked up. **Farmbot is alive and moving. Controllable from laptop access.**+**Current Status** - Farmbot construction is 90% complete. Tool holders need to be mounted, Vacuum and water inputs need to be hooked up. **Farmbot is alive and moving. Controllable from laptop access.**
-//Check for documentation ​updates for wiring after 12/16/16. Any questions about this build please contact us!//+//Wiring ​documentation ​availableScroll down! Any questions about this build please contact us!//
 {{ :​farmbots:​picture1.jpg?​300|}} {{ :​farmbots:​picture1.jpg?​300|}}
Line 109: Line 109:
 //Stepper Motors// - We used Dual Shafted stepper motors and tapped the plate on the shorter shaft end to hold the encoders. Below is the basic wiring for the power connections. No wiring diagram yet available for the encoders, as we have not figured it out yet. //Stepper Motors// - We used Dual Shafted stepper motors and tapped the plate on the shorter shaft end to hold the encoders. Below is the basic wiring for the power connections. No wiring diagram yet available for the encoders, as we have not figured it out yet.
 {{:​farmbots:​farmbot_wiring.jpg|}} {{:​farmbots:​farmbot_wiring.jpg|}}
 +//Power Wiring// - GNL is wired to a household plug in. G - Green (Ground). N - White (Neutral). L - Black (Line).
 +{{:​farmbots:​pi_to_ramps.png|}}
 +//Wiring Photos//
 +{{:​farmbots:​20161215_085749.jpg?​300|}}{{:​farmbots:​20161215_085523.jpg?​300|}}{{:​farmbots:​20161215_085529.jpg?​300|}}{{:​farmbots:​20161215_085553.jpg?​300|}}
farmbots/northeastern-wisconsin-technical-college-farmbot.txt · Last modified: 2016/12/15 17:10 by mgrimmett
